Posted January 24, 200619 yr comment_153237 When you have your running lights on that includes the front turn signals right? Are they bright or dim? when you click on the turn signals while having the running lights on dose the bulb go from dim to bright or bright to dim or bright to off or what?74 260Z Link to comment https://www.classiczcars.com/forums/topic/18658-running-lights/ Share on other sites More sharing options...
January 24, 200619 yr comment_153259 On my late '74 the running-/turnsignal lights are combo bulbs with two filaments. One (dim)for the running lights and one(brighter) for the turnsignal function. On my car there are three wires from the harnass to the turnsignal units to service the two filaments in the combo bulbs. So when operating the runninglights, one filament gets constant power. The turnsignal filament only gets power from the flasher unit when you operate the turnsignals. Link to comment https://www.classiczcars.com/forums/topic/18658-running-lights/#findComment-153259 Share on other sites More sharing options...
January 24, 200619 yr Author comment_153284 OK so when you turn on your running lights your turn bulb is dim and you want to turn it flashs from dim to bright? think thats what ur saying Link to comment https://www.classiczcars.com/forums/topic/18658-running-lights/#findComment-153284 Share on other sites More sharing options...
January 24, 200619 yr Author comment_153286 nvm i got my anwser and what i just said is correct if ne one else cares...thx Link to comment https://www.classiczcars.com/forums/topic/18658-running-lights/#findComment-153286 Share on other sites More sharing options...
