I've got the dreaded brake squeal, it is now time to do something about it (well it has been for a while). I've read that these can be bought from MSA, but i can't see them there:
http://www.zcarparts.com/store/merchant.mvc?Screen=CTGY&Category_Code=SBC
I've also read that brake grease can solve the problem, but doesn't always. So, i figure that if i'm going to do something about this then i should do it properly and get some shims. Where else can i get these from? Is there anywhere in Australia that has them? Could i make them myself?
Thanks,
Jon
https://www.classiczcars.com/forums/topic/18662-brake-shims/
You should be able to get them from just about any Nissan dealer...Left shim P/N: 41085-E4100 Right shim P/N: 41084-E4100. You also might try the following url: http://www.nissanparts.cc
Have enclosed a picture as well in case you need to show the parts person what they look like...otherwise they kind of look at you like a deer when you shine your headlights in it's eyes...and say something like "Say What???"
webdawg1
Several years working on brakes for a living lead me to say that you should use both shims and brake grease.
  • If you are re-using existing pads, clean the back surface and edges of the backing plates as well.
  • Apply a thin coat of the grease to the shim where it sits on the backing plate.
  • Apply a thin coat to the edges of the backing plate, with special attention to any spots that look like they have metal-to-metal contact.
  • Apply a thin coat to the piston surface where it contacts the backing plate and shim.
  • Use new retaining hardware if possible, or clean the existing hardware thoroughly.
  • Put a thin coat of grease on the cups of the spring plates that go between the two retaining pins.
not too long ago I bought a set of shims and all the rest of the caliper hardware (pins, clips, and springs) from a local parts store. I forget what brand was on the box, but when I opened the box there was a paper tag inside the plastic bag that contained all of the parts with the name "Girling" on it. IIRC it was less than $20 and I got all new everything (except pads).
I also use silicone brake grease and shims in combination.
I'll try a Nissan dealer on Friday and see how i go. Thanks for the help.
260DET, i originally tried to get Bendix Ultimates but have been informed that they are now a discontinued item (they are bringing in another performance replacement soon though).
Thanks
Jon
  • 5 months later...
I tried some of the anti-squeal compound, and it is working for now. How lond does the liquid stuff (from a tube applicator) last?
I also saw spray-on stuff, what is that like?
From the Haynes book, the anti-squeal shims in the pictures look like a very thin paper-like material, is that what it's made of? I'm wondering because another person here used cloth-backed duct tape, but it didn't last more than several years.
thx
It's the pads.
You squeeze them together, and they make heat, which is a kind of energy. This energy has an equivalence in vibration/sound, so it makes a noise which is transferred to the brake caliper. Using the shims or anti-squeal compound is like a layer of sound-deadening insulation.
