Is it interchangable with a 260 hub?
I'm beefing up the front stut with 260 struts and need to know as I have a terra trip probe mounted on the fount strut.
The probe has 2 bolts secured onto the hub which acts as a trigger and rather than modify the 260 hub, I would rather swap them over.
Can I use the 240 hub on the 260 strut?
TIA
https://www.classiczcars.com/forums/topic/18665-240z-front-hub/
The 240 and 280 hubs are different in the US. They have a 10mm different offset for the rotor. If you're talking about the 77, I think you would have the same hubs as the 280Z has in the US.
OK, for future reference.
The hubs are different.
240 is 17mm thick rotor is 40mm
260 is 24mm thick rotor is 33mm
Both have the same overall measurements and a 240 hub complete with disc rotor fits on a 260 strut.
