What is the proper procedure for checking the voltage where the harness plugs into the air regulator? I turned the key on hooked up the ecu , set the voltmeter to 20v dc and I get no voltage reading but I do have continuity in the circuit. Should the car be running for voltage check? The air regulator gives 60ohms but no continuity and flunks pin test so need a new one of those. Any ideas would help before I pull out the fuel pump relay.Thanks
https://www.classiczcars.com/forums/topic/18700-no-voltage/
