Just a quick update. Made the trip to the junkyard today and picked up the bolts I needed. The bolts circled on the picture at the beginning of this post are actually longer than I expected. The bolts on the opposite side of the cam, though shorter, will still require several washers to shorten them up enough to use. They should work fine after shimming. Just thought I would give a heads up to anyone that may need this info in the future. Also, a 10mm socket/hex, extension, and 1/2" breaker bar would be the preferred method of removal. The bolts almost made my 3/8" Craftsman rachet blow a nad, but it thankfully held together. Thanks again everyone.
