Posted February 1, 200619 yr comment_154178 This will drive you bananas! 21.71 seconds was my best time. It's harder than it looks. Try this .. The object of the game is to move the red block around without getting hit by the blue blocks or touching the black walls. If you can go longer than 30 seconds you are phenomenal. The US Air Force uses this for fighter pilots. They are expected to go for at least 2 minutes. Give it a try !! click here: http://tinyurl.com/56t9u Link to comment https://www.classiczcars.com/forums/topic/18732-try-this/ Share on other sites More sharing options...
February 1, 200619 yr comment_154192 ooh, 17.222, I aint no fighter pilot. Link to comment https://www.classiczcars.com/forums/topic/18732-try-this/#findComment-154192 Share on other sites More sharing options...
February 1, 200619 yr comment_154198 17.5 but my mouse is all weird... very entertaining btw :-P Link to comment https://www.classiczcars.com/forums/topic/18732-try-this/#findComment-154198 Share on other sites More sharing options...
February 1, 200619 yr comment_154200 38.422 secs. The 'action' of the squares wasn't very smooth (possibly related to 56K Dial Up conncection?) and I think that helped me last as long as I did. Link to comment https://www.classiczcars.com/forums/topic/18732-try-this/#findComment-154200 Share on other sites More sharing options...
February 1, 200619 yr comment_154202 16.828 for me. Link to comment https://www.classiczcars.com/forums/topic/18732-try-this/#findComment-154202 Share on other sites More sharing options...
February 1, 200619 yr comment_154203 No good with a touch pad. Link to comment https://www.classiczcars.com/forums/topic/18732-try-this/#findComment-154203 Share on other sites More sharing options...
February 1, 200619 yr comment_154207 19.865 and 19.765, but that was over many, many tries and several 1.4s etc. My average seems to be around 13 seconds. Link to comment https://www.classiczcars.com/forums/topic/18732-try-this/#findComment-154207 Share on other sites More sharing options...
February 1, 200619 yr comment_154223 24.8...after many tries. What a fun game. Link to comment https://www.classiczcars.com/forums/topic/18732-try-this/#findComment-154223 Share on other sites More sharing options...
February 1, 200619 yr comment_154225 Ok I just lasted 21.7 seconds on it. I guess my wife is right I am pretty quick Link to comment https://www.classiczcars.com/forums/topic/18732-try-this/#findComment-154225 Share on other sites More sharing options...
February 1, 200619 yr comment_154227 The only problem is that this particular link the blue blocks aren't random they move the same way every time you play so you can just get used to a pattern (ie. pacman)...but if you were tested on the first try and got to 2 minutes, man you are the stud...cause I sure didn't. Link to comment https://www.classiczcars.com/forums/topic/18732-try-this/#findComment-154227 Share on other sites More sharing options...
February 1, 200619 yr comment_154231 0.375 seconds...Doh! Link to comment https://www.classiczcars.com/forums/topic/18732-try-this/#findComment-154231 Share on other sites More sharing options...
February 1, 200619 yr comment_154236 42.156 This was after about an hour and a half and 5 college guys betting every last dime they have seeing who is the best!!! So far I win, but i'm sure this will go on for atleast another 5 or 6 hours!! who needs sleep anyway? I swear after 30 sec. its all luck, and you pray your palms dont start to get sweaty and loose grip!!! Link to comment https://www.classiczcars.com/forums/topic/18732-try-this/#findComment-154236 Share on other sites More sharing options...
