My EFI harness has some issues like no voltage at air reg connector and a couple other failed pin tests.Relay checks out so I figure it's a wire problem. I've been chasing this for a few weekends and feel it's time for another approach.Is it worth buying a used harness or try and build another .Or the other option of cut/splice the promlem areas? Thanks
https://www.classiczcars.com/forums/topic/18774-worth-it/
