Sorry to hear about your MISPLACEMENT of the key & original key chain. You are just too youg to be doing thoughs sort of things. They will likely show up and be right where you left them....hopefully! Good luck!
Worst case senario: call a locksmith. He'll be able to look into the door locking mechanism and cut a new key based on what he sees inside (if he's good).
But goodluck. Here's a tip, try looking where you WOULDN'T expect them to be...
