reinstalled fuse box after clutch replacement.
There is a WHT/ RED wire with a rubber cap.
The schematic shows connection to fuse box.
Would any one know where this wire connects to?
I might be wrong as its been awhile since I had my fuse box out, but if memory serves isnt this the 12v feed wire from the battery? it would explain the rubber boot to protect it from grounding on metal.
is it a lagre guage wire? like 12 ish...assuming its the power feed wire for the fusebox, it probably bolts on to the top underside of the fusebox.
