A/C for '73, factory or dealer installed?
gogriz91
As for your other question, Garth, the only thing that made me think that it could be factory was the location of his evaporator box. But then when I thought about it, it's the 810s and the Maximas that have the box in the passenger footwell. Good call Moonpup, I guess we both missed that. I'm going to be quiet now until I see some pictures.:stupid:
Here's some pics of what I believe to be a Nissan Distributor(not a dealer) installed AC system in my '73 240Z. Also, I have a '73 owner's manual which references 240Zs w/AC in tables for vehicle stopping distance, recommended tire size/inflation, and aceleration and passing ability.
AC Controls
Receiver/Dryer
You can see this on the passenger side firewall.
http://jaderunner.com/Auto/240Z/images/Purchase/034.JPG
Evaporator
http://jaderunner.com/Auto/240Z/images/Evaluation/IMG_3574.JPG
http://jaderunner.com/Auto/240Z/images/Evaluation/IMG_3576.JPG
That's aftermarket. The main giveaway is the barrier hoses with clamps rather than machined hoses for the high and low side lines. Also the Sankyo compressor is aftermarket and they are still available today under the name Sanden. They bought out Sankyo some time back. That's a nice install compared to the usual York system that was so commonly used back then. The evaporator box does look almost 'factory'. The best way to take care of the hole that will be left when you remove the evaporator box would be to go the junkyard and get another blower motor housing. Thanks for the pictures Pete and Adam. I have added them to my early Z a/c research folder. Pete, can you post a picture of the control on your dash?
BTW, the A/C system in my car is non-functional and missing the compressor and condenser. I don't need it where I live anyway so I have removed the rec/dryer and will probably remove the evap at some point in the future to give the passenger some more leg room.
  • Who's Online   1 Member, 0 Anonymous, 521 Guests (See full list)
