Posted February 13, 200619 yr comment_155810 What exactly do you use in the 240z steering rack? a search suggests grease but the FSM says a API GL4 oil :surprised Link to comment https://www.classiczcars.com/forums/topic/18894-240z-rack-lube/ Share on other sites More sharing options...
February 13, 200619 yr comment_155814 Stephen, pulled the outer end boots off the other day and my old "Z Doctor" had used the same grease he put in the wheel bearings. That was on the ends I could see. I'll check my manual and see what it says. I'm at the same point. Link to comment https://www.classiczcars.com/forums/topic/18894-240z-rack-lube/#findComment-155814 Share on other sites More sharing options...
February 13, 200619 yr comment_155823 I have always used wheel bearing grease.Will Link to comment https://www.classiczcars.com/forums/topic/18894-240z-rack-lube/#findComment-155823 Share on other sites More sharing options...
February 13, 200619 yr comment_155826 The inner and outer tie rod ends should be greased. But if the lube is low inside the rack and pinion tube itself (a rare problem), GL4 gear oil should be added. Link to comment https://www.classiczcars.com/forums/topic/18894-240z-rack-lube/#findComment-155826 Share on other sites More sharing options...
February 13, 200619 yr comment_155867 ditto on the wheel bearing grease.i had the grease fittings on 1 side and a plastic plug on the other side which i replaced with a grease fitting. shot it with the grease gun and all seems well.never heard about the gl4 oil being used, i'd be interested to hear more. Link to comment https://www.classiczcars.com/forums/topic/18894-240z-rack-lube/#findComment-155867 Share on other sites More sharing options...
February 14, 200619 yr Author comment_155884 Thanks, I've got the hole on the LHs of rack which is pluged for grease I guess. Below the slack adj nut I have another small bolt, which I opened expecting oil to run out but it appears to be blocked with grease, from the manual you have to fill the rack by removing the slack nut etc.On closer inspection it seems the LH inner tie rod is loose, can this be replaced or does it mean the whole rack refurb Link to comment https://www.classiczcars.com/forums/topic/18894-240z-rack-lube/#findComment-155884 Share on other sites More sharing options...
June 27, 2024Jun 27 comment_666822 Ok searched greasing the steering rack on the site, here we are. 73 240z, purchased a rebuilt steering rack ungreased. What is the procedure? how do you know it's greased enough? Single grease fitting under the steering shaft spline. Do I need to add a second grease fitting on the passenger side small bolt? Thanks. Link to comment https://www.classiczcars.com/forums/topic/18894-240z-rack-lube/#findComment-666822 Share on other sites More sharing options...
June 27, 2024Jun 27 comment_666823 Having a hard time understanding why they would rebuild a rack and not grease it during the process. Just can’t imagine how it has not been lubricated. Link to comment https://www.classiczcars.com/forums/topic/18894-240z-rack-lube/#findComment-666823 Share on other sites More sharing options...
June 27, 2024Jun 27 comment_666834 All you can really do now is remove the rubber boot on the P/S, turn the steering wheel all the way to the right so that it is exposing as much of the P/S rack as possible and grease it up well. Turn the wheel all the way back and forth to spread the grease around and before you put the boot back on put some grease inside the boot. It will be decades before it needs greasing again. Link to comment https://www.classiczcars.com/forums/topic/18894-240z-rack-lube/#findComment-666834 Share on other sites More sharing options...
June 27, 2024Jun 27 comment_666854 On 6/27/2024 at 10:05 AM, grannyknot said: All you can really do now is remove the rubber boot on the P/S, turn the steering wheel all the way to the right so that it is exposing as much of the P/S rack as possible and grease it up well. Turn the wheel all the way back and forth to spread the grease around and before you put the boot back on put some grease inside the boot. It will be decades before it needs greasing again. P/S rack? Link to comment https://www.classiczcars.com/forums/topic/18894-240z-rack-lube/#findComment-666854 Share on other sites More sharing options...
June 27, 2024Jun 27 comment_666855 On 6/27/2024 at 6:24 PM, bluez said: P/S rack? Passenger side I think. Link to comment https://www.classiczcars.com/forums/topic/18894-240z-rack-lube/#findComment-666855 Share on other sites More sharing options...
June 27, 2024Jun 27 comment_666856 On 6/27/2024 at 6:50 PM, CanTechZ said: Passenger side I think. The rack that sticks out of the housing when the steering wheel is turned all the way to the right Link to comment https://www.classiczcars.com/forums/topic/18894-240z-rack-lube/#findComment-666856 Share on other sites More sharing options...
