My car has been reasonably trouble-free since I bought it, but one thing that continually seems to stuff up is the fuel pump. I've bought 3 new ones now... but it's having the same problem again. It's weird, I'll describe it.
Upon starting the engine (seems to be the same whether its cold, warm or hot) the fuel pump will pretty much immediately start leaking fuel. I was told the first three times it was just a broken seal so I have just replaced it but come on, the problem must be originating elsewhere, surely?
As soon as you start driving, the leaking stops. When idling at traffic lights or in a car park it seems not to leak either. Just on startup.
Do you guys have any thoughts, ideas or solutions?
Note that I have 240Z round-top hitachis on an otherwise standard L24 in a 240K. And yes, I did search the forums first.
https://www.classiczcars.com/forums/topic/18903-fuel-pump-woes/Share on other sites
