78 280zcar Posted February 16, 2006 Share #1 Posted February 16, 2006 I checked the oil in my car the other day and found out that there is gas in the oil and the oil is very thin:mad: . I have a fuel injected Z and just rebuilt it 2000 miles ago. What would cause this and should I change the bearings again. I am leaning towards the injectors but need to know if I have to take the engine out again:paranoid: HELP Link to comment Share on other sites More sharing options...
montoya_fan01 Posted February 16, 2006 Share #2 Posted February 16, 2006 not a good thing!cant help with the why as I only experienced this on a carbed Toyota truck (accel pump on carb was stuck). If you've run the engine long with this condition, I'd worry about bearings, cam, crank, and rings. Link to comment Share on other sites More sharing options...
kenz240z Posted February 16, 2006 Share #3 Posted February 16, 2006 Did you rebuild the engine yourself, or have a shop do it? If it was done at a shop, did it come with a warranty? Have you talked to the shop?Running on thin oil could definitely damage the parts Montoya mentioned. Link to comment Share on other sites More sharing options...
78 280zcar Posted February 16, 2006 Author Share #4 Posted February 16, 2006 I done it myself. well I know where my tax return is going:mad: Link to comment Share on other sites More sharing options...
Fun_in_my_z Posted February 16, 2006 Share #5 Posted February 16, 2006 This could be due to a blown head gasket, a cracked block, or stuck vavle. Or it could be a number of other things.Take a flashlight and go over the block very closely if its cracked you should be able to find it. Link to comment Share on other sites More sharing options...
MikeW Posted February 16, 2006 Share #6 Posted February 16, 2006 Bad fuel pump? It's not like there are many places where fuel could get into the oil.Edit: I see now that you probably have an electric pump so it has to be somewhere else. Are all of the injectors working properly? Link to comment Share on other sites More sharing options...
240ZX Posted February 16, 2006 Share #7 Posted February 16, 2006 This could be due to a blown head gasket, a cracked block, or stuck vavle. Or it could be a number of other things.Take a flashlight and go over the block very closely if its cracked you should be able to find it. Bill, you post whore you. I applaud your efforts on possible causes but, I don't think a blown head gasket, a cracked block, or a stuck valve will cause fuel to enter the oil system!!! However, an overly large set of boobs could do it! How you might ask......being distracted during engine assembly!!? Link to comment Share on other sites More sharing options...
Ed Posted February 16, 2006 Share #8 Posted February 16, 2006 This could be due to a blown head gasket, a cracked block, or stuck vavle. Or it could be a number of other things.Take a flashlight and go over the block very closely if its cracked you should be able to find it.Say what? How? Link to comment Share on other sites More sharing options...
ezzzzzzz Posted February 16, 2006 Share #9 Posted February 16, 2006 The only thing that comes to mind is a stuck injector flooding a cylinder. Link to comment Share on other sites More sharing options...
MikeW Posted February 16, 2006 Share #10 Posted February 16, 2006 The only thing that comes to mind is a stuck injector flooding a cylinder.That's what I was thinking. Of course, if he's not getting a spark then it would be even worse. How's the car running? Link to comment Share on other sites More sharing options...
78 280zcar Posted February 17, 2006 Author Share #11 Posted February 17, 2006 Thanks for the comments, I dont think the block is cracked, I had it checked when I had it torn down along with the head which was cracked. It runs pretty rough at idle, I was thinking it was an injector too, that was the only thing I didnt change on the rebuild, except for one that had a cracked tip and I just changed that one with a pick and pull special. Since I have the JSK fuel rail on there I can just take the rail off with the injectors still on it and check it for leaks after I build up pressure, or is that a bad idea? I just hope that it is not one of the rings. About the gas being in the oil, I checked it again today, it doesnt smell like there is alot of gas in there. Do you guys think that I can drain the oil and put in new oil and filter run it for a few minutes and change the oil and filter again? Please tell me something good, I really dont want to have to change the bearings again!:disappoin I will do a leak down test and compression test of course before I touch anything. Link to comment Share on other sites More sharing options...
MikeW Posted February 17, 2006 Share #12 Posted February 17, 2006 I think you should pull and examine all of the spark plugs. I'm guessing that one of them is going to be different than the others ... Link to comment Share on other sites More sharing options...
