greetings to all, straight to the point:tapemouth
I have been watching my 1977 280Z from the back and I always felt the i had a tilted right wheel, but i just discovered that i had an inclined back of my car from the right down by measuring the clearance between the car's body and the top of rear wheels..
I jacked my car (from both sides at the back on stands) i was shocked when I saw the right wheel hanging higher that the left one!?:surprised
does it mean that the right shock is different from the left one? since I noticed that I have a different brake drum on the right than the one on left (original with fins)
or the sway bar could cause such a thing??
in case of shock's problem, does Tokico have a specific type for the 1977 280Z? or I can go for any shock absorber with the same shape??
thank you in deposit..
Mohamed..
