Posted June 10, 200222 yr comment_8556 Ok. My ZED is shod with 195\70\14 CRAPPY TIRES. I'm on my way to make a swap in mid July for new wheels. I want 15 inches. What size should I go? I don't want to spend a fortune and would like some suggestions on nice wheels. Merci beaucoup for your help! Link to comment https://www.classiczcars.com/forums/topic/1902-switching-wheels/ Share on other sites More sharing options...
June 10, 200222 yr comment_8558 You say 15" and then you ask what size wheel, so I assume yu mean width? 15X7 will comfortably fit any tyre you want to put on a Z.If you mean what size tyre, then you have fallen into the most often asked question catagory. Lowered? Here's the thing: Compare 35 different pix of Z's (lowered, stock, low profile, tall, 0 offset, +1 offset, coilovers, etc, etc, etc, etc,) and you will see 35 different tyre/fender relationships. Springs sag, strut isolators are different heights, all kinds of thigs happen to make things variable. You will find tons of tyre recommendations. I have had 195/75/14's 195/50/15's unlowered and 195/50/15 and 225/50 15's lowered. They all work fine. Some have more gap than you probably want. just do a bunch of research. Link to comment https://www.classiczcars.com/forums/topic/1902-switching-wheels/#findComment-8558 Share on other sites More sharing options...
June 10, 200222 yr Author comment_8560 I'm tired I think. Just left Montreal this pm and I'm in tampa right now for my job for 2 weeks. Well, I think I will stick with 195 50 15 since my ZED is lowered 1,5 inches. I don't think that any larger tires will do the job. I need 113,5mm for the offset, is that right? Link to comment https://www.classiczcars.com/forums/topic/1902-switching-wheels/#findComment-8560 Share on other sites More sharing options...
