Ok.
My ZED is shod with 195\70\14 CRAPPY TIRES.
I'm on my way to make a swap in mid July for new wheels.
I want 15 inches.
What size should I go?
I don't want to spend a fortune and would like some suggestions on nice wheels.
Merci beaucoup for your help!:confused:
https://www.classiczcars.com/forums/topic/1902-switching-wheels/
You say 15" and then you ask what size wheel, so I assume yu mean width? 15X7 will comfortably fit any tyre you want to put on a Z.
If you mean what size tyre, then you have fallen into the most often asked question catagory. Lowered? Here's the thing: Compare 35 different pix of Z's (lowered, stock, low profile, tall, 0 offset, +1 offset, coilovers, etc, etc, etc, etc,) and you will see 35 different tyre/fender relationships. Springs sag, strut isolators are different heights, all kinds of thigs happen to make things variable. You will find tons of tyre recommendations. I have had 195/75/14's 195/50/15's unlowered and 195/50/15 and 225/50 15's lowered. They all work fine. Some have more gap than you probably want. just do a bunch of research.
I'm tired I think.
Just left Montreal this pm and I'm in tampa right now for my job for 2 weeks.
Well, I think I will stick with 195 50 15 since my ZED is lowered 1,5 inches.
I don't think that any larger tires will do the job.
I need 113,5mm for the offset, is that right?:confused:
