I am in the process of having my interior redone. After taking off the rear right interior panel, I found that the fuel vapor tank didn't fit correctly :( . After further scrutiny, I found the tank is a replacement tank from a newer model Z. So, I need to find a good used plastic fuel vapor tank for my early model 70 Z. I have no junkyards to check here in Phoenix with Zs, so am trying to see if anyone has one lying around. Anyone have one out there they would sell?
https://www.classiczcars.com/forums/topic/19101-need-70-240z-fuel-vapor-tank/
Hi Duffman,
I have VIN 1222 and it had no provisions for the evaporation tank... I have often wondered at which point Datsun decided that gas fume recovery tanks were needed...Govt mandated I s'pose...
I hope one of the local Gurus will shed some light.
David
Btw, I do have an extra in good shape. Shoot me a line if inerested...Volgolf@aol.com
Thanks, David, I e-mailed you to check on your vapor tank. I also would be interested to know when Datsun first started using the vapor tanks. I know they started with plastic for the first 1 to 2 years then switched to metal. Anyone have any additional thoughts? Are they necessary?
I beat on the metal tank with a BFH until it no longer hit the quarter panel, you'll also need the interior panel for the metal tank, since the tank is larger the interior panel has a bigger bulge. Problem that I was having is cracking the plastic tanks. I have a hunch it was a result of autoxing, but I broke 3 of them (try to find 3 plastic tanks!!!) before I switched to the metal tank.
