Posted March 4, 200619 yr comment_158118 I am in the process of having my interior redone. After taking off the rear right interior panel, I found that the fuel vapor tank didn't fit correctly . After further scrutiny, I found the tank is a replacement tank from a newer model Z. So, I need to find a good used plastic fuel vapor tank for my early model 70 Z. I have no junkyards to check here in Phoenix with Zs, so am trying to see if anyone has one lying around. Anyone have one out there they would sell? Link to comment https://www.classiczcars.com/forums/topic/19101-need-70-240z-fuel-vapor-tank/ Share on other sites More sharing options...
March 4, 200619 yr comment_158119 Hi Duffman, I have VIN 1222 and it had no provisions for the evaporation tank... I have often wondered at which point Datsun decided that gas fume recovery tanks were needed...Govt mandated I s'pose... I hope one of the local Gurus will shed some light.David Btw, I do have an extra in good shape. Shoot me a line if inerested...Volgolf@aol.com Link to comment https://www.classiczcars.com/forums/topic/19101-need-70-240z-fuel-vapor-tank/#findComment-158119 Share on other sites More sharing options...
March 4, 200619 yr Author comment_158121 Thanks, David, I e-mailed you to check on your vapor tank. I also would be interested to know when Datsun first started using the vapor tanks. I know they started with plastic for the first 1 to 2 years then switched to metal. Anyone have any additional thoughts? Are they necessary? Link to comment https://www.classiczcars.com/forums/topic/19101-need-70-240z-fuel-vapor-tank/#findComment-158121 Share on other sites More sharing options...
March 4, 200619 yr comment_158137 I have a June 1970 model car, and have the plastic one. Link to comment https://www.classiczcars.com/forums/topic/19101-need-70-240z-fuel-vapor-tank/#findComment-158137 Share on other sites More sharing options...
March 5, 200619 yr comment_158246 I have a June 1970 model car, and have the plastic one.Ditto on my 01/71. If anyone wants it I'll sell it to you. Link to comment https://www.classiczcars.com/forums/topic/19101-need-70-240z-fuel-vapor-tank/#findComment-158246 Share on other sites More sharing options...
March 5, 200619 yr comment_158247 My #4396, 5/70 had one at one time... ;-) Link to comment https://www.classiczcars.com/forums/topic/19101-need-70-240z-fuel-vapor-tank/#findComment-158247 Share on other sites More sharing options...
March 5, 200619 yr comment_158252 Is it possable , that this car came from Canada? It's my understanding that the evap tank was not required for the non US market early on . Gary Link to comment https://www.classiczcars.com/forums/topic/19101-need-70-240z-fuel-vapor-tank/#findComment-158252 Share on other sites More sharing options...
March 5, 200619 yr Author comment_158254 Those of you that have/had the plastic one, did you replace it with a more modern metal one? I have a metal one that doesn't fit. How did you make yours fit? Link to comment https://www.classiczcars.com/forums/topic/19101-need-70-240z-fuel-vapor-tank/#findComment-158254 Share on other sites More sharing options...
March 6, 200619 yr comment_158262 I beat on the metal tank with a BFH until it no longer hit the quarter panel, you'll also need the interior panel for the metal tank, since the tank is larger the interior panel has a bigger bulge. Problem that I was having is cracking the plastic tanks. I have a hunch it was a result of autoxing, but I broke 3 of them (try to find 3 plastic tanks!!!) before I switched to the metal tank. Link to comment https://www.classiczcars.com/forums/topic/19101-need-70-240z-fuel-vapor-tank/#findComment-158262 Share on other sites More sharing options...
March 6, 200619 yr Author comment_158289 So, Jon, did you use a different interior panel to allow the metal tank to fit or did you use the BFH to "alter" the panel as well? Link to comment https://www.classiczcars.com/forums/topic/19101-need-70-240z-fuel-vapor-tank/#findComment-158289 Share on other sites More sharing options...
March 6, 200619 yr comment_158290 No, I got an interior panel off of a 72 I think. Hammers and plastic trim pieces don't mix... Link to comment https://www.classiczcars.com/forums/topic/19101-need-70-240z-fuel-vapor-tank/#findComment-158290 Share on other sites More sharing options...
March 6, 200619 yr comment_158296 The factory service manual says- “A reservoir is provided so as to relief expansion and bubbles due to heating.(for California, U.S.A.)” Link to comment https://www.classiczcars.com/forums/topic/19101-need-70-240z-fuel-vapor-tank/#findComment-158296 Share on other sites More sharing options...
