Can someone please look up the part number for the indicator switch assemblies used in the C110 and C210?
It appears that C110 1973 are different to C110 1974 - 77. No idea what the difference might be to a C210!
Unfortunately the C110 and C210 models are not covered in the various CD parts book copies I have.
thanks
Art
looking at the parts book for Aussie C110 May 1976 the C110 is 25540-S0100 - ASSY Switch, turn signal
and according to the Jap C210 manual it is 25540-U7401 for all models up to 79/07, it also mentions something about 25540-U7402 which could be a replacement number?
Thanks for that Kent.
I was interested in the eBay one but couldn't get an answer on the part no from the box.
Photo showed a small connector similar to that on the headlight switch (about 20mm by 15mm). Our '73 KHGC110 000302 has a ten way connector about 35mm by 14mm.
It was still tempting as rewiring to a new/old connector isn't hard.
Part no's both starting with 25540 tends to indicate they may well be minor variants on the same base hardware.
Recently Browsing 0
