Posted March 6, 200619 yr comment_158317 Where would the block be cracked if water froze? I am assuming the pass sidebut none are visible,all freeze plugs(new) look good and in place. #3 cyl had water in it.There was water in #3 cyl. Could it possibly cracked the head and not the block? Link to comment https://www.classiczcars.com/forums/topic/19128-block-cracked/ Share on other sites More sharing options...
March 6, 200619 yr comment_158320 Doug that would have been my guess. And welcome to the site!! Link to comment https://www.classiczcars.com/forums/topic/19128-block-cracked/#findComment-158320 Share on other sites More sharing options...
March 6, 200619 yr Author comment_158325 Thanks Tom. I have access to another Z for parts so the head would be no prob. I am toying with a 5.0 swap or a Grand National turbo V6(got a complete one) Link to comment https://www.classiczcars.com/forums/topic/19128-block-cracked/#findComment-158325 Share on other sites More sharing options...
March 6, 200619 yr comment_158328 When the Z engine overheats the head ends up warping. Usually causing the head gasket to fail and allowing water into the #3 or #4 cylinder. If you had a cracked block wouldn't the water be leaking on the outside? Link to comment https://www.classiczcars.com/forums/topic/19128-block-cracked/#findComment-158328 Share on other sites More sharing options...
March 6, 200619 yr Author comment_158331 It could be cracked anywhere in the water jackets I guess. It hasn't been overheated,it has only been driven in his yard after installing the rebuilt motor but he didn't put antifreeze in it or drain it.That's why I was asking since I saw no water to outside. Thought it might not have hurt the block. Link to comment https://www.classiczcars.com/forums/topic/19128-block-cracked/#findComment-158331 Share on other sites More sharing options...
March 6, 200619 yr comment_158335 If you are in coastal Ga, I don't believe it has been cold enough for long enough this winter to have that issue. Link to comment https://www.classiczcars.com/forums/topic/19128-block-cracked/#findComment-158335 Share on other sites More sharing options...
