Holes under sound deadner
pimp1911
No holes on the console, sorry man, plug them up. Looks like your having fun, it will we over soon. I was surprised to find surface rust way up under the tar paper where it held moisture. Glad I took it all off. Looks like you are too. Good luck
The two rear ones actually look more like the holes for the Luggage Strap Hold Down. Not sure about the next one further back, unless it's for the Luggage Stop Bar. This was an aftermarket Chrome Bar that stopped your packages from sliding forward.
The one on the hump looks like it could have been from the center console screw hole. Or from an "accessory" that someone mounted.
E
No holes in the hump in that position, I'd say fill 'em.
Enrique,
Do you still think those other holes would be for the luggage straps ??
They look to be in the wrong spot for that.
Hard to tell from the photo just where that area is. My guess is to the left of the spare wheel well.
The holes wouldn't have been for a towbar mount would they ????
That's my guess.
Rick.
:devious: :devious:
