Email logins are now active ×
Shortening Shifter length???
peng155
Question....
I was looking at the MSA short throw shifter Kit.... Not only was I hoping to shorten the throw, but also I wanted to shorten the shifter length above the center console by about an inch.
The MAS kit only shortens the throw, and the length remains the same... Does anyone know if it's possible, and how to go about shorten the length of the shifter??
Thanks
Make sure you have a surplus shifter lever before you cut yours down. The levers in these cars are pretty long, and cutting it SHOULDN'T cause any problems, but shifter cutting is pretty common in the ricer circles, and can really throw of the balance of a shift lever, making shifts heavier or more difficult.
I just wouldn't cut up your only shift level on the off chance that you'll be unhappy with the result.
You'd have to be some kind of super-wussy to have trouble with the effort required to shift a Z with a cut down shifter. I've got mine shortened and I'm using the 4 speed shifter in a 5 speed, so the length between the pivot and the end is longer, meaning even less leverage. My wife shifted our Z while autoxing and she's a whopping ~140 lbs.
I'd be much more concerned about getting power steering than getting a heavy shift knob if you're that weak anyway. Sorry if this came off too harsh, but shifting effort should be the least of anyone's worries, and if it's not that person shouldn't be driving an old Z car.
  • Who's Online   2 Members, 0 Anonymous, 236 Guests (See full list)
