Posted March 18, 200619 yr comment_159866 The vent has an arrow embossed on the top of it, which direction should the arrow be facing? Thanks, Mike Link to comment https://www.classiczcars.com/forums/topic/19258-5-sp-tramsmission-vent-which-direction/ Share on other sites More sharing options...
March 19, 200619 yr Author comment_159961 Anyone have a tranny setting around that they can look at the vent (pressure relief) for me? Think I'll point it toward the front of the car unless I hear otherwise, Thanks, Mike Link to comment https://www.classiczcars.com/forums/topic/19258-5-sp-tramsmission-vent-which-direction/#findComment-159961 Share on other sites More sharing options...
March 20, 200619 yr comment_160058 Nice question. The gearbox just pulled fom my ZX import has the arrow facing to the rear. I would have thought it would face the front, whatever, the open part of the vent should face to the rear. Link to comment https://www.classiczcars.com/forums/topic/19258-5-sp-tramsmission-vent-which-direction/#findComment-160058 Share on other sites More sharing options...
March 20, 200619 yr comment_160077 I was going to answer this question but I didn't have a tranny to look at so i would have been going on memory. It would make sense that it would face the rear since the air flow would prevent it from venting properly if the opening was facing toward the front. Link to comment https://www.classiczcars.com/forums/topic/19258-5-sp-tramsmission-vent-which-direction/#findComment-160077 Share on other sites More sharing options...
March 20, 200619 yr comment_160127 I pulled my 5 speed last night. The arrow is facing forward. Link to comment https://www.classiczcars.com/forums/topic/19258-5-sp-tramsmission-vent-which-direction/#findComment-160127 Share on other sites More sharing options...
March 20, 200619 yr comment_160135 great mixed opnions...i say rear to suck air out as air goes by it Link to comment https://www.classiczcars.com/forums/topic/19258-5-sp-tramsmission-vent-which-direction/#findComment-160135 Share on other sites More sharing options...
March 20, 200619 yr Author comment_160169 The top is round and open all the way around, it does not need to "suck" air, the issue is the end that is built into the shaft that goes down in the tranny, it has a "cutaway" section on it. Come up 3/16ths" or so and imagine about half the shaft removed up to that height, in a nice pretty arc. Looking in the tranny I can't see any real advantage to one direction or the other but I bet those engineers put that cutaway there and an arrow to insure a certain direction was used at installation on purpose. If you pulled your 5sp last night and no one has been there in awhile it may be correct, still leaning to "arrow front". Good thing I have time to get hung up on something that is probably a moot point, but haveto believe they cut the bottom and put an arrow on it for a reason. Which way, Which way???? MikeAnother Question: If our knees bent backwards could we still ride a bicycle? Link to comment https://www.classiczcars.com/forums/topic/19258-5-sp-tramsmission-vent-which-direction/#findComment-160169 Share on other sites More sharing options...
