Posted March 19, 200619 yr comment_159886 Are there any internal diff? Outside i know there was a 2400 on the early z but is there any reason you cant swap all of the covers as you please? Link to comment https://www.classiczcars.com/forums/topic/19264-valve-cover-differences/ Share on other sites More sharing options...
March 19, 200619 yr comment_159896 No! They all fit all of the Lseries inline 6s!Will Link to comment https://www.classiczcars.com/forums/topic/19264-valve-cover-differences/#findComment-159896 Share on other sites More sharing options...
March 19, 200619 yr comment_159899 So how many different looking ones are out there? PS Since the original question has been answere i though I will change the topic slightly Link to comment https://www.classiczcars.com/forums/topic/19264-valve-cover-differences/#findComment-159899 Share on other sites More sharing options...
March 19, 200619 yr comment_159900 That is correct! The ONLY difference is the lettering on the top. There are 5 that I have seen and are as follows: "NISSAN OHC" "NISSAN 2400 OHC" "NISSAN 2000 OHC" "NISSAN" "TURBO" "BOB SHARP" "" <---------this one is blank on top, I believe this to be a modification (i.e. ground off letters) Furthermore, if you have the 2400 or NISSAN styles and wish to sell them to me for a fair price I'm always on the lookout for one of these. Link to comment https://www.classiczcars.com/forums/topic/19264-valve-cover-differences/#findComment-159900 Share on other sites More sharing options...
March 19, 200619 yr comment_159902 These are the ones I have seenNissan OHCNissan 2400Nissan TurboNissan and A blank one with No script-was not polished, and did not appear to have been machined(casting marks on the top)(Oh sure TexasZ beat me to the punch while I was typing...again!) Link to comment https://www.classiczcars.com/forums/topic/19264-valve-cover-differences/#findComment-159902 Share on other sites More sharing options...
March 19, 200619 yr comment_159916 texasz said: That is correct! The ONLY difference is the lettering on the top. There are 5 that I have seen and are as follows:"NISSAN OHC""NISSAN 2400""NISSAN""TURBO"/QUOTE]Mine says: " NISSAN 2400 OHC " Link to comment https://www.classiczcars.com/forums/topic/19264-valve-cover-differences/#findComment-159916 Share on other sites More sharing options...
March 19, 200619 yr comment_159971 My '70 Series I also reads: " NISSAN 2400 OHC " Link to comment https://www.classiczcars.com/forums/topic/19264-valve-cover-differences/#findComment-159971 Share on other sites More sharing options...
March 19, 200619 yr comment_160003 There is a difference on one of them.The cover that just says "NISSAN" in big letters is slightly taller. It is a JDM item, and if installed in a S-30 with new motor mounts, you cannot install several makes of strut bar. BTW I just sold my JDM "NISSAN" cam cover, or should say traded away. I have a new PDK Fabrication strut bar and could no longer use it. Link to comment https://www.classiczcars.com/forums/topic/19264-valve-cover-differences/#findComment-160003 Share on other sites More sharing options...
March 20, 200619 yr comment_160031 hls30.com said: (Oh sure TexasZ beat me to the punch while I was typing...again!)This seems to happen to the two of us rather frequently.Great minds.... Link to comment https://www.classiczcars.com/forums/topic/19264-valve-cover-differences/#findComment-160031 Share on other sites More sharing options...
March 21, 200619 yr comment_160223 This is what the Nissan 2400 OHC looks like..... Link to comment https://www.classiczcars.com/forums/topic/19264-valve-cover-differences/#findComment-160223 Share on other sites More sharing options...
March 21, 200619 yr comment_160271 Actually, the Nissan L-series 6 cylinder engine debuted 5 years before the S30-series Z in the 1965 'Cedric Special Six'. Valve covers from the early six cylinder engines won't fit the 'late' heads ( ie E30 / E31 / E88 / N42 etc etc ) because the method of affixing them was different. Here's a pic of the top end of an L20A six from that 1965 'Cedric Special Six': Link to comment https://www.classiczcars.com/forums/topic/19264-valve-cover-differences/#findComment-160271 Share on other sites More sharing options...
March 21, 200619 yr comment_160290 Thanks Alan,Looks like an awful lot like a longer version of a Sr311 cover...perhapse the L series evolved from the changes in its engine?(not to hijack the thread...)Will Link to comment https://www.classiczcars.com/forums/topic/19264-valve-cover-differences/#findComment-160290 Share on other sites More sharing options...
