Posted March 20, 200619 yr comment_160048 HI Just wondering if anyone can point me in the right direction... I need to get some new Needles and Jets or nozzels for my original Hitachi/SU carbs off a 1973 240z... when looking for the nozzels i was told that the 240z came with hitachi carbs not SU however in the handbook i have they are labled SUs.... i was just wondering if someone could clear this up for me as i'm unsure as to what i should be looking for.... Have contacted the main carbie group up here in Brisbane and they told me to hit up the forums as they are unable to locate them.... Any help would be greatly appreciated... Cheers Josh Link to comment https://www.classiczcars.com/forums/topic/19283-240z-carbies/ Share on other sites More sharing options...
March 20, 200619 yr comment_160065 Z therapy USA perhaps Link to comment https://www.classiczcars.com/forums/topic/19283-240z-carbies/#findComment-160065 Share on other sites More sharing options...
March 20, 200619 yr comment_160080 Josh use the forum search function and you will get more carb info than you can use! Good luck Link to comment https://www.classiczcars.com/forums/topic/19283-240z-carbies/#findComment-160080 Share on other sites More sharing options...
March 20, 200619 yr comment_160096 the carburetors are Hitachi SU's. They are a skinner's union design, made by hitachi. Try www.ZTherapy.com for needles, and check out the Hitachi SU tech pages for other SU information: http://www.jetlink.net/~okayfine/sutech.html Link to comment https://www.classiczcars.com/forums/topic/19283-240z-carbies/#findComment-160096 Share on other sites More sharing options...
March 20, 200619 yr comment_160164 If they are the original flat tops that came on the 73', ditch em and get some round (dome)tops. You'll be much happier in the end. Link to comment https://www.classiczcars.com/forums/topic/19283-240z-carbies/#findComment-160164 Share on other sites More sharing options...
March 21, 200619 yr Author comment_160288 Thanks alot for the replys i really appreciate the help.... From my limited understanding of the situation from all the reading that i've undergone the Australian 1973 240z carbies are the 3 screw round top hitachi version which were the 1972 style american 240z... not the flat top version you guys have on your 1973 240z or the previous owner may have already gotten rid of the flat tops and replaced the carbies with the round ones. I have hopefully sourced some parts which wasn't easy and it looks like i may have to get them shipped from overseas...Thanks again for everyone helpJosh Link to comment https://www.classiczcars.com/forums/topic/19283-240z-carbies/#findComment-160288 Share on other sites More sharing options...
March 21, 200619 yr comment_160325 AFAIK, the flat tops first appeared over here in '74 on the 260Z. Correct me if I'm wrong. Link to comment https://www.classiczcars.com/forums/topic/19283-240z-carbies/#findComment-160325 Share on other sites More sharing options...
March 21, 200619 yr comment_160338 AFAIK, the flat tops first appeared over here in '74 on the 260Z. Correct me if I'm wrong.You're spot on Murph.You could try Rare Spares for needles.MOM Link to comment https://www.classiczcars.com/forums/topic/19283-240z-carbies/#findComment-160338 Share on other sites More sharing options...
March 21, 200619 yr comment_160341 Has anyone tried Nissan Aus for needles?What about Potter @ All-Z? Link to comment https://www.classiczcars.com/forums/topic/19283-240z-carbies/#findComment-160341 Share on other sites More sharing options...
