reegs01 Posted March 23, 2006 Share #1 Posted March 23, 2006 i was reading that some people eliminate the vapor tank and plug up the unneeded openings on the fule tank . if i do this do i need to have a charcoal canister mounted in the engine compartment ? Link to comment Share on other sites More sharing options...
beandip Posted March 23, 2006 Share #2 Posted March 23, 2006 I don't have one . Link to comment Share on other sites More sharing options...
ncz Posted March 23, 2006 Share #3 Posted March 23, 2006 I had the Webers installed and the mechanic left the line to the engine compartment open, as the manifolds diidn't have a fitting for the vapor return line. Didn't seem to hurt anything and never had a fume problem. so may not be necessary for the cannister Link to comment Share on other sites More sharing options...
TomoHawk Posted March 23, 2006 Share #4 Posted March 23, 2006 The vapor tank and vapr canister work together. The vapor tank condenses the majority of gas vapor right off the fuel tank, and the vapor canistor gets what little is left, so you don't have the fumes. Search for other threads on this topic to see what people have done. Link to comment Share on other sites More sharing options...
sblake01 Posted March 23, 2006 Share #5 Posted March 23, 2006 TomoHawk, what you're saying is more applicable to the EFI cars, like ours, where due to the higher fuel pressure, the cannister is more of a necessity. I've seen quite a few carbed cars without a vapor tank or charcoal cannister without the problem of fumes. Link to comment Share on other sites More sharing options...
ncz Posted March 23, 2006 Share #6 Posted March 23, 2006 Good point, Mike let us know what year car you have and put it on your profie, that will help Link to comment Share on other sites More sharing options...
montoya_fan01 Posted March 23, 2006 Share #7 Posted March 23, 2006 TomoHawk, what you're saying is more applicable to the EFI cars, like ours, where due to the higher fuel pressure, the cannister is more of a necessity. I've seen quite a few carbed cars without a vapor tank or charcoal cannister without the problem of fumes.Stephen is quite correct. In fact, 240Z's didn't have a charcoal canister until the 73 model year in North America. Link to comment Share on other sites More sharing options...
dogma420 Posted March 23, 2006 Share #8 Posted March 23, 2006 why would you need a charcoal canister? Don't eliminate none of that stuff on FI--Check out technical articles. Link to comment Share on other sites More sharing options...
240ZX Posted March 23, 2006 Share #9 Posted March 23, 2006 Its a common thing to remove the old plastic vapor tank. Somewhere in the system, it is advisible to have a tank vent....collapsed tanks are not much fun! What I did was to fabricate a vent in the gas cap that also prevents fuel from slosching out when G-loads are present from cornering. Link to comment Share on other sites More sharing options...
Ricklandia Posted March 24, 2006 Share #10 Posted March 24, 2006 I'll play a little devils advocate here on this one. Do you NEED one? No. Is it a good idea? Yeah. the whole idea of vent canisters is for keeping gasoline vapors from escaping into the atmoshphere - a good, no great idea, especially if you want to think "green". Every "modern" car has them in one sense or another, a sealed fuel system. It doesn't effect performance in any way and personally I think it's a good idea to keep it in place if you already have one. If you don't, and like many here do you only drive your Z for pleasure, you can "justify" not needing one simply because if the fact that not too many still drive old cars like we do. OTOH, it's a good thing to do for no other reason than to realize that having gas powered "toys" to play with is a luxury we may not have for too much longer, and we should at least try to do what we can to extend what time we have to enjoy this luxury as best we can. I know it's a very "PC" attitude to take, but there it is. JMHO Link to comment Share on other sites More sharing options...
reegs01 Posted March 24, 2006 Author Share #11 Posted March 24, 2006 well im actually running a v8 in a 240 with a 4 barrel and usually you dont need them but i was just curious cause i purchased my tank with all the holes plugged but the top one to the rear which i figured goes to the filler neck .and i just wanted to be sure before i put everything back together . a vented gas cap sounds like a good idea is there one that can be purchased like a universal or one from a later model maybe ? Link to comment Share on other sites More sharing options...
dogma420 Posted March 25, 2006 Share #12 Posted March 25, 2006 The fuel vapor tank is made out of metal in 240z's.Check out my tech article:http://www.classiczcars.com/forums/showthread.php?t=19034It mainly deals with POR15'ing the entire gas tank, but also explains how to reroute the fuel tank hoses correctly when removing the vapor tank. Link to comment Share on other sites More sharing options...
