Recently Browsing 0
Is anybody using this combo sucessfully? I just did a test fit and it looks like the KYB boots are a little too wide for this spring. I guess the inner diameter of the stock springs must be a little wider. I'm not sure if I want the boot constantly rubbing on the inside of the springs and ultimately bunching up near the top. This won't be a big deal on the rear because I can strap the base of the boot to the strut housing. However, you can't do this on the front because the strut rod doesn't turn with the strut, which would end up twisting the boot. Any and all feedback is appreciated.
https://www.classiczcars.com/forums/topic/19367-tokico-red-springs-kyb-strut-boots/Share on other sites
