Posted March 26, 200618 yr comment_160962 Is anybody using this combo sucessfully? I just did a test fit and it looks like the KYB boots are a little too wide for this spring. I guess the inner diameter of the stock springs must be a little wider. I'm not sure if I want the boot constantly rubbing on the inside of the springs and ultimately bunching up near the top. This won't be a big deal on the rear because I can strap the base of the boot to the strut housing. However, you can't do this on the front because the strut rod doesn't turn with the strut, which would end up twisting the boot. Any and all feedback is appreciated. Link to comment https://www.classiczcars.com/forums/topic/19367-tokico-red-springs-kyb-strut-boots/ Share on other sites More sharing options...
March 26, 200618 yr comment_160966 I had Tokico red's on a stock shock, thats about it,soon Im going to have a coil setup Link to comment https://www.classiczcars.com/forums/topic/19367-tokico-red-springs-kyb-strut-boots/#findComment-160966 Share on other sites More sharing options...
