March 27, 200619 yr Author comment_161090 I have the larger toyota 4x4 brakes and have no problems. Right now I do not have my hub dust caps on. I will try to alter them later. If anyone knows of dust cap alternatives let me know. I would like to keep those centercaps. Link to comment https://www.classiczcars.com/forums/topic/19385-new-wheels/?&page=2#findComment-161090 Share on other sites More sharing options...
March 27, 200619 yr comment_161094 Very nice! I love the look of these. Let us know if you figure out an alternative for the dust caps. I'd hate to run without them. Link to comment https://www.classiczcars.com/forums/topic/19385-new-wheels/?&page=2#findComment-161094 Share on other sites More sharing options...
March 27, 200619 yr comment_161115 Which Toyota brakes are you running, the vented, or non-vented? How much clearance is there between the caliper face and the wheel? What brand of tires did you go with? Link to comment https://www.classiczcars.com/forums/topic/19385-new-wheels/?&page=2#findComment-161115 Share on other sites More sharing options...
March 27, 200619 yr comment_161119 I love the color of your new rims, the anthracite fits in perfectly with the forest green. Good job dude! Link to comment https://www.classiczcars.com/forums/topic/19385-new-wheels/?&page=2#findComment-161119 Share on other sites More sharing options...
March 27, 200619 yr Author comment_161120 I have non vented rotors. 1 inch clearance between front face (parellel with wheel)of brake and inside face of wheel. My tires are Falken Ziex 512. Link to comment https://www.classiczcars.com/forums/topic/19385-new-wheels/?&page=2#findComment-161120 Share on other sites More sharing options...
March 27, 200619 yr comment_161168 That's good news. The vented rotor swap should fit fine. Have you had them on long enough to know if they rub the fender lips front or rear? Link to comment https://www.classiczcars.com/forums/topic/19385-new-wheels/?&page=2#findComment-161168 Share on other sites More sharing options...
March 27, 200619 yr Author comment_161213 I went out this weekend and so far so good. Rear is fine and has plenty of room. The fronts are close to my valance but I have not felt, seen or heard the tire hit it. I will go for a little more of a spirited drive and if it a new problem rises I will post. The closest part is the lower perch. It is 1/4 inch or so from the tire where it seats with the wheel. The tire shop said if it doesnt rub now it shouldnt later. Link to comment https://www.classiczcars.com/forums/topic/19385-new-wheels/?&page=2#findComment-161213 Share on other sites More sharing options...
July 23, 200618 yr comment_175704 louisf said: I went out this weekend and so far so good. Rear is fine and has plenty of room. The fronts are close to my valance but I have not felt, seen or heard the tire hit it. I will go for a little more of a spirited drive and if it a new problem rises I will post. The closest part is the lower perch. It is 1/4 inch or so from the tire where it seats with the wheel. The tire shop said if it doesnt rub now it shouldnt later.Try backing down a hill with a hard turn, like out of a driveway. Or backing and turning hard on to a side hill. Usuall the right front has additional caster, so back to the right as if turning to the left. If I am going to rub, those are the conditions where I will rub.Those wheels are tempting! Link to comment https://www.classiczcars.com/forums/topic/19385-new-wheels/?&page=2#findComment-175704 Share on other sites More sharing options...
July 23, 200618 yr comment_175706 I wonder how that would look on 110 red? It sure is nice on dark green.Nice pick! Link to comment https://www.classiczcars.com/forums/topic/19385-new-wheels/?&page=2#findComment-175706 Share on other sites More sharing options...
August 9, 200618 yr comment_177659 Damn I wish these came in a 16 but 15 will have to do. 225/50 in the front but what about the rear? Link to comment https://www.classiczcars.com/forums/topic/19385-new-wheels/?&page=2#findComment-177659 Share on other sites More sharing options...
October 1, 200618 yr comment_184335 Wstepler said: 225/50 in the front but what about the rear?I am wondering the samething? I just wanna be able to fit a 235/60/15 on the back. Link to comment https://www.classiczcars.com/forums/topic/19385-new-wheels/?&page=2#findComment-184335 Share on other sites More sharing options...
October 18, 200717 yr comment_225152 Well I ended up buying 16x8 (+0mm offset) and 245/50/16 tires on all 4 corners. Link to comment https://www.classiczcars.com/forums/topic/19385-new-wheels/?&page=2#findComment-225152 Share on other sites More sharing options...
