Posted March 29, 200619 yr comment_161507 does anyone know if the 78 280z rear end can be aligned? the rear end of the car doesn't line up strait with the wheel well Link to comment https://www.classiczcars.com/forums/topic/19419-rear-end-alignment/ Share on other sites More sharing options...
March 29, 200619 yr comment_161509 Not from the factory. The only factory adjustment is front toe. You can shim caster in the front too, but toe is the only real adjustment.If the rear is really out camber bushings from G Machine are the cheapest easiest fix. Motorsport Auto has them. Link to comment https://www.classiczcars.com/forums/topic/19419-rear-end-alignment/#findComment-161509 Share on other sites More sharing options...
