Posted March 29, 200619 yr comment_161581 I installed a set of CV axles on my '71 along with a R200 L/S. I was checking the tranny fluid and noticed grease building up on my LHS above the axle. I checked it out and it seems to be leaking from around the stainless steel clamp. There is no hole. Just seeping out from the seal around the clamp. Can I get a new clamp for this axle? I thought about just getting a hose clamp but they are a bit too wide. Do they make narrower clamps for these CV's? Where do I go? Parts houses or ???? Link to comment https://www.classiczcars.com/forums/topic/19434-cv-leaking/ Share on other sites More sharing options...
March 29, 200619 yr comment_161586 That's a tough one to find, surprisingly. Might try a driveline shop. They come in every CV boot kit out there, so it's not like they're uncommon, but I tried everyone and the only one who had them was Nissan and they wanted, and this is not a joke, $80 for all the clamps. Uh... no thanks.I found a stainless strap from Harbor Freight when I repacked my CV's. Here's what I used: http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=92515They are not ideal and on the big end you have to hook two together, but I was able to get them pretty damn tight and I figure once they're on there they don't really have to handle too much stress. I haven't tried them yet and probably won't for another year or so, so you could be the guinea pig... Link to comment https://www.classiczcars.com/forums/topic/19434-cv-leaking/#findComment-161586 Share on other sites More sharing options...
March 30, 200619 yr comment_161639 Where do I go? Parts houses or ????Just buy a whole boot kit for between $7-$19. These generally come with the type you can slip on and crimp while the unit is mounted to the car. I'm not sure what year the CV joint came from but Back Arnley and Dorman both make replacements for the 70-83 Zs. You just use a pair of end nippers to crimp it on.Check Rockauto.com or even your local parts store. Link to comment https://www.classiczcars.com/forums/topic/19434-cv-leaking/#findComment-161639 Share on other sites More sharing options...
March 30, 200619 yr Author comment_161659 I changed the clamp and now we will see if that is really the cause. I did find one small nick in the boot. I also siliconed that up. We will see. Thanks for your help. Nice S/S tie wraps! Link to comment https://www.classiczcars.com/forums/topic/19434-cv-leaking/#findComment-161659 Share on other sites More sharing options...
