Updated pics.. cleaned her up, installed a new air dam, new tires
PrOxLaMuS©
A question. What holds the front spoiler on? Just the side bolt on the fenders and under the blinkers?
I ask because i just bought one and there's no center support like the stock piece, seems like it would stress and crack the fiberglass with no support in the middle.
Keep of the curbs and parking lot guides, be carefull of driveways with steep transitions, avoid running over thing and you will be OK
Will
6 bolts.. 2 under the side marker thing (behind the wheel well plastic) using the factory mouting brackets which holds the factory valence on
1 close to the front grill (well used to be grill) under the headlight scoop
then same on the other side
Oh and my air dam is Urethane plastic.. so it flexes and wont crack when I hit something
Looks real good. I like the stance, I thought it would sit higher with the AZ springs, but I actually really like it.
So when are you gonna ditch the louvers? I mean, I guess they could be hiding some valuable speakers or amps or something. Each to his own, hehe...
Carbon fiber.........:love:
BTW, what size tires are you running?
the bottom of the doors are door kick panels..
and the trim along the side of the doors under the window is to protect from door dings..
and I can tell you, having it be my daily driver, and parking in a garage everyday in downtown Denver at school, it protects my door from nasty dings.
Plus they are all dealership options.. I kinda want the car to look SOME what original
