Posted March 30, 200618 yr comment_161627 First of all my brother and I were stocking up my Z on the needies antifreeze,oil, etc. So I pop open the oil pan and I am not suprised the oil is pure black. So as I am laying on the ground with the jug under the oil pan chunks of mud start plopping out, not a huge amount but, enough to make me worried. What do you think is wrong/ what will I have to do to clean everything up?:stupid: :stupid: Link to comment https://www.classiczcars.com/forums/topic/19439-dirt-in-oil-pan/ Share on other sites More sharing options...
March 30, 200618 yr comment_161634 Are you sure it was dirt based mud or was it perhaps sludge caused by moisture mixing with the water? In any event,at a minimum I'd probably put a new oil filter on it, run some engine flush through it, drain it, change the filter again, drive it for a few hundred miles and then do it all again one more time, assuming that everything looks ok after that. If not, repeat ad infinitum. Link to comment https://www.classiczcars.com/forums/topic/19439-dirt-in-oil-pan/#findComment-161634 Share on other sites More sharing options...
March 30, 200618 yr Author comment_161746 Well I have already changed the oil put a new filter on and all that good stuff. And I can't really drive a couple hundred miles. Link to comment https://www.classiczcars.com/forums/topic/19439-dirt-in-oil-pan/#findComment-161746 Share on other sites More sharing options...
March 30, 200618 yr comment_161753 well, since it's an S30, you should be able to remove the oil pan. You might want to drain all of the oil, remove the pan, clean it out with some degreaser, and put it back up with a new gasket. Link to comment https://www.classiczcars.com/forums/topic/19439-dirt-in-oil-pan/#findComment-161753 Share on other sites More sharing options...
March 31, 200618 yr Author comment_161896 Thank you I will try that. Link to comment https://www.classiczcars.com/forums/topic/19439-dirt-in-oil-pan/#findComment-161896 Share on other sites More sharing options...
April 1, 200618 yr comment_161974 want a hint as to how to get it off easier? Well, get a power drill, and put an adaptor in it for a 10mm socket. Then that will zip all of the bolts out fast, I can do it in under 3 minutes now with the drill, and then finish up with a ratchet. The pan will come right off of the engine, you just have to angle the pan right to clear the transmission bellhousing and engine crossmember. While you're at it, clean the crap off of your oil sump filter. Link to comment https://www.classiczcars.com/forums/topic/19439-dirt-in-oil-pan/#findComment-161974 Share on other sites More sharing options...
April 1, 200618 yr Author comment_162026 Thanks for the heads up. Link to comment https://www.classiczcars.com/forums/topic/19439-dirt-in-oil-pan/#findComment-162026 Share on other sites More sharing options...
