Posted March 30, 200619 yr comment_161720 Are Koyo and NGK brands good quality brands for replacing front and rear wheel bearings or should I stick to Nissan's own ? Link to comment https://www.classiczcars.com/forums/topic/19444-wheel-bearings/ Share on other sites More sharing options...
March 30, 200619 yr comment_161721 Nissan uses both Koyo and NSK, so they are the same thing you'd likely get from the dealer. I assume that wasn't supposed to be NGK but NSK. Link to comment https://www.classiczcars.com/forums/topic/19444-wheel-bearings/#findComment-161721 Share on other sites More sharing options...
March 30, 200619 yr comment_161730 rear outer bearing #nsk B31z-16C4rear inner bearing # nachi RLS10 T C4These were probably replaced at one time.You should be able to go to any bearing place and they can match them up. As far as brands, let others chime in. Link to comment https://www.classiczcars.com/forums/topic/19444-wheel-bearings/#findComment-161730 Share on other sites More sharing options...
