Posted April 5, 200619 yr comment_162324 Where should I start to investigate about this problem? The alternator has been changed last year and the voltage regulator about two years ago.Could it be a bad contact somewhere? Link to comment https://www.classiczcars.com/forums/topic/19512-amp-gauge-reading-up-to-45/ Share on other sites More sharing options...
April 5, 200619 yr comment_162359 Not much info to go on... does it read +45 all time, at idle, only when you are driving.. ??? Link to comment https://www.classiczcars.com/forums/topic/19512-amp-gauge-reading-up-to-45/#findComment-162359 Share on other sites More sharing options...
April 6, 200619 yr Author comment_162399 I have had the charging system checked this afternoon. It seems that the voltage regulator is the problem. Link to comment https://www.classiczcars.com/forums/topic/19512-amp-gauge-reading-up-to-45/#findComment-162399 Share on other sites More sharing options...
