I came across an early 1980's 200SX in a JY. I didn't see much of anything that would work on a Z. It did have a similar, if not the same, fuel injection system.
The one I saw had a 4-speed overdrive automatic transmission (L4N71B), but it had a different bell housing than a Z transmission. I thought about snatching the tranny as a backup since I'm putting a Maxima auto into my wife's 280Z.
I believe you can use the rear calipers for a rear disk brake conversion, and I think I remember reading somewhere that some of them had R200 LSDs in them. Maybe even a 4.11 but I'm not sure about either.
The early 80's model I saw did not have an independant rear suspension, hence no R200. I also thought it had rear drum brakes but I could be wrong.
That was the 1984-85 200SX turbo that had the 4.11 R200 open diff.
The non-turbo had a 4.11 R180.
The Z20/Z22 series engines are common in the trucks. Not all that great. The CA18de/and turbo and CA20De engines are pretty good little guys. I saw a CA18DE swap in a 510 recently. But I think those engines were 1984+
I think that the transmission will work on a Z-car. I know that in a Datusn 510 people commonly swap a dogleg 5-speed that i think comes from a 200sx. Give it a check, if reverse is where first normally is then you probably have a useable transmission. Only thing is that those transmissions can't take much power, probably 200-250hp. That is if you would really want a dogleg 5-speed, the mount would be in the wrong place also. Doglegs are normally desired for autocross because the 2-3 shift is striat up and down, making the most common shift happen quicker.
The 'dogleg' 5 speed, that is used as a common swap in the early PL510 (68-73), comes from the earlier 200sx (S10 77-79) or the 510 (A10 78-79) . They both have L engines. What I said above about the cars (S110 80-83) and 510 (A10 80-81) with NAPS engines applies to the five speed too. The trannys from the NAPS engine cars are slanted and won't work in a Z.
