Posted April 13, 200619 yr comment_163293 My rear choke is coming on ok when i pull back my lever, but the front one does not move, although i can push up on the linkage at the carb and the nozzle will pull down. What should i look for to repair this? Is it a case of a broken cable, or could the cable be binding up? Alos can you still get OEM cable? I have heard bike cable is not the best thing to use.This is just one thing i'm trying to fix in my ongoing saga, for more details look at the thread"rust in gas bad running now".Thanks folks!! Link to comment https://www.classiczcars.com/forums/topic/19610-choke-cable-replace-or-repair/ Share on other sites More sharing options...
April 13, 200619 yr comment_163301 Sounds like the cable snapped, since the lever still moves and the other cable still actuates the other choke. The cables are easy to find (at least around here). Link to comment https://www.classiczcars.com/forums/topic/19610-choke-cable-replace-or-repair/#findComment-163301 Share on other sites More sharing options...
April 13, 200619 yr comment_163305 Deadflo,we have choke cables hear at Z-sport [in everett] give me a call if you need one and I'll ship it out,[ask for johnny]or you could go to your local dealership and order one. performance nissan provides us with our stock orders so I know they can still get them.JZM.. Link to comment https://www.classiczcars.com/forums/topic/19610-choke-cable-replace-or-repair/#findComment-163305 Share on other sites More sharing options...
April 13, 200619 yr comment_163310 I heard you can also use the solid throttle cable that is used on many lawnmowers. Not sure if there is any truth to this or not. Link to comment https://www.classiczcars.com/forums/topic/19610-choke-cable-replace-or-repair/#findComment-163310 Share on other sites More sharing options...
April 13, 200619 yr comment_163312 Thats just what he needs to put a john dear choke cable on his 1971 DATSUN 240Z. JZM.. Link to comment https://www.classiczcars.com/forums/topic/19610-choke-cable-replace-or-repair/#findComment-163312 Share on other sites More sharing options...
April 13, 200619 yr comment_163316 I've heard that motorcycle shops can replace the inner (wire) cable and regrease your choke cable assembly for less $$ than buying OEM new Choke cables. Link to comment https://www.classiczcars.com/forums/topic/19610-choke-cable-replace-or-repair/#findComment-163316 Share on other sites More sharing options...
April 13, 200619 yr comment_163325 montoya_fan01 said: I've heard that motorcycle shops can replace the inner (wire) cable and regrease your choke cable assembly for less $$ than buying OEM new Choke cables.Buy the new cables they are not that much $$$....ask JZM. I had a set that broke and cause the plastic on the consol that they were mounted to break. This is an automatic consol too....so I am going to have to come up with another way to mount the choke. The point is; don't take a chance on ruining your consol like what happened to me get new cables. Link to comment https://www.classiczcars.com/forums/topic/19610-choke-cable-replace-or-repair/#findComment-163325 Share on other sites More sharing options...
April 13, 200619 yr Author comment_163337 Ok well it sound like I should probabaly get some cable, what do you recomend to lube em up with ? Is it difficult to install? Link to comment https://www.classiczcars.com/forums/topic/19610-choke-cable-replace-or-repair/#findComment-163337 Share on other sites More sharing options...
April 13, 200619 yr comment_163339 Whats the pro date on your Z? The dealer says that pre 12/71 are no longer available.however if found new,the price would be around $120.00-130.00.JZM.. Link to comment https://www.classiczcars.com/forums/topic/19610-choke-cable-replace-or-repair/#findComment-163339 Share on other sites More sharing options...
April 13, 200619 yr comment_163341 Montezuma said: Buy the new cables they are not that much $$$....ask JZM. I had a set that broke and cause the plastic on the consol that they were mounted to break. This is an automatic consol too....so I am going to have to come up with another way to mount the choke. The point is; don't take a chance on ruining your consol like what happened to me get new cables.OEM replacement is the ideal situation, but not everyone can afford the $60 - $300 (depending on what year car), and the downtime to source and receive OEM parts. Having a motorcycle shop rebuild the choke cable asembly results in a virtually NEW part.FWIW, it wast the broken cable that caused the console to break, it was the operator who kept yanking on the handle instead of finding the problem and fixing it. Been there, done that, learned my lesson.deadflo: I use lithium grease to lube my unbroken cable. I got a littl tool at the cycle shop that helps direct grease from my little grease gun into the outersleeve of the cable. It was a cheap tool to buy. Link to comment https://www.classiczcars.com/forums/topic/19610-choke-cable-replace-or-repair/#findComment-163341 Share on other sites More sharing options...
April 13, 200619 yr comment_163342 montoya_fan01 said: OEM replacement is the ideal situation, but not everyone can afford the $60 - $300 (depending on what year car), and the downtime to source and receive OEM parts. Having a motorcycle shop rebuild the choke cable asembly results in a virtually NEW part.FWIW, it wast the broken cable that caused the console to break, it was the operator who kept yanking on the handle instead of finding the problem and fixing it. Been there, done that, learned my lesson.bought it that way....I am WAY too smart to ever break something on my otherwise original car. Let me tell you it is no joy starting an automatic without working choke cables. Link to comment https://www.classiczcars.com/forums/topic/19610-choke-cable-replace-or-repair/#findComment-163342 Share on other sites More sharing options...
April 13, 200619 yr comment_163343 transmission type would have NO effect on starting an engine. Driving on a cold engine yes, starting one, no. Link to comment https://www.classiczcars.com/forums/topic/19610-choke-cable-replace-or-repair/#findComment-163343 Share on other sites More sharing options...
