Madison Ga, taking pics later today.Went to tune it today and got surprised!!!!!!!
Found "NO POINTS". . There are 2 vacuum ports at the manifold where the front carb mounts that are blocked off, wonder if I can use one of them .? ................ If you use manifold vacuum the advance will go to full advance at start up and fall when the throttle is opened , just the opposite of what you want. Until you find out what the settings are for that ignition . I would just set the timing at 10 degrees BTDC . Vacuum advance should be connected to carb vacuum .
Ok ! have some pics they are here (after approval)
http://www.classiczcars.com/photopost/showgallery.php?cat=500&ppuser=7742
Alos have some of the new engine pics and will load them when it lets me! getting an error , I assume its because I have others pending!
