Posted April 16, 200619 yr comment_163782 Alright y'all. I'm in the middle of swapping out my front struts (for Tokico HP's) and springs (Eibach). Once I got the whole deal apart I noticed that inside the Upper Spring Seat there is a red dusty residue which was aparently a bushing at one point in time. Does anyone know if this piece is readily available? It isn't a listed part in the MSA catalog, unless it's part of #23-4361 Spring Seat. Any advice? Thanks -Nate Link to comment https://www.classiczcars.com/forums/topic/19656-strut-bushing-thingy/ Share on other sites More sharing options...
April 16, 200619 yr comment_163783 This is simply a bump stop. You can replace it with any aftermarket bump stop such as those from Energy Suspension, or go with the stock rubber replacement from Black Dragon/VB. Link to comment https://www.classiczcars.com/forums/topic/19656-strut-bushing-thingy/#findComment-163783 Share on other sites More sharing options...
April 16, 200619 yr comment_163784 the part number is 23-4376 and called an upper strut bearing, they are $22.46 each (page 83 2 items below the spring seat listingVery common iten that almost always need replacing after 34+ years. do both.Mine was also a "red dusty MESS" and the bump stop had split in half Link to comment https://www.classiczcars.com/forums/topic/19656-strut-bushing-thingy/#findComment-163784 Share on other sites More sharing options...
April 16, 200619 yr comment_163786 CoastGuardZ said: Alright y'all. I'm in the middle of swapping out my front struts (for Tokico HP's) and springs (Eibach). Once I got the whole deal apart I noticed that inside the Upper Spring Seat there is a red dusty residue which was aparently a bushing at one point in time. Does anyone know if this piece is readily available? It isn't a listed part in the MSA catalog, unless it's part of #23-4361 Spring Seat. Any advice? Thanks-NateNate:What you have discovered it that the "bump stop" that is integral to the upper spring seat has dried out and turned to dust over the years. It is meant to keep your strut inserts (cartridges) from bottoming out and being destroyed. It's a common thing to find this 35 year old part to be gone.It is not available separately as an OEM part, you'd have to replace the entire upper spring seat to get it back to OEM. However, it IS available in Polyeurothane from MSA and other places like Black Dragon (VB), etc. Link to comment https://www.classiczcars.com/forums/topic/19656-strut-bushing-thingy/#findComment-163786 Share on other sites More sharing options...
April 16, 200619 yr comment_163787 :stupid: Guess I took too long to compose my reply. Link to comment https://www.classiczcars.com/forums/topic/19656-strut-bushing-thingy/#findComment-163787 Share on other sites More sharing options...
April 16, 200619 yr comment_163788 No matter what it is (bearing or bushing) rubber or metal) REPLACE them BOTH! Your whole strut assembly pivets on that bearing and the bump stop helps to protect it. Replace 'em both.JM2CWDave Link to comment https://www.classiczcars.com/forums/topic/19656-strut-bushing-thingy/#findComment-163788 Share on other sites More sharing options...
April 16, 200619 yr Author comment_163789 Zs-ondabrain said: the part number is 23-4376 and called an upper strut bearing, they are $22.46 each (page 83 2 items below the spring seat listingVery common iten that almost always need replacing after 34+ years. do both.There is a bearing also but it is between the mount insulator and spring seat. This is between the seat and the strut rod. Enigma seems to have it with the Bump stop. Now I'm curious how tall the original one is/was so that maybe I can pick a generic one up at Autozone or Advance, they usually carry some Energy Suspension stuff.Thanks again... I always love the quick response and outpouring of help.Nate Link to comment https://www.classiczcars.com/forums/topic/19656-strut-bushing-thingy/#findComment-163789 Share on other sites More sharing options...
April 16, 200619 yr Author comment_163790 Dave I think you're right with the replace them both strategy... just kinda sucks, I haven't got to drive it yet since the snow melted and the salt washed away. Oh, well guess I'll have to wait another couple of weeks.Nate Link to comment https://www.classiczcars.com/forums/topic/19656-strut-bushing-thingy/#findComment-163790 Share on other sites More sharing options...
April 16, 200619 yr comment_163792 Nvm...........you guys hashed it out.When doing my suspension, I replaced the front strut bearings, the rear strut spacers with items from VB, and replaced the bump stops with cut down versions of the ones that came with my Energy Suspension Master Bushing Kit. The Tokico spring installation instructions recommended cutting down the bump stops to minimize the amount of travel lost by installing shorter springs. Link to comment https://www.classiczcars.com/forums/topic/19656-strut-bushing-thingy/#findComment-163792 Share on other sites More sharing options...
April 16, 200619 yr comment_163793 Zs-ondabrain said: the part number is 23-4376 and called an upper strut bearing, they are $22.46 each (page 83 2 items below the spring seat listingVery common iten that almost always need replacing after 34+ years. do both.Mine was also a "red dusty MESS" and the bump stop had split in halfDave: Which catalog are you looking at? I have the current (I think) MSA catalog and I can't find the part # you mentioned. (cover is gray and has purple 240Z and 350Z on it. It's only a year or 2 old)I did find PN # 23-4196 on Page 97 which is for a pair of Urethane Bump Stops @ $15.95EDIT: On Pg 118 I find the part number you mentioned, but it is for the actual roller bearing that allows the strut assembly to rotate to make right and left turns Link to comment https://www.classiczcars.com/forums/topic/19656-strut-bushing-thingy/#findComment-163793 Share on other sites More sharing options...
April 16, 200619 yr comment_163795 damn, I'm a step behind you guys this morning. Link to comment https://www.classiczcars.com/forums/topic/19656-strut-bushing-thingy/#findComment-163795 Share on other sites More sharing options...
April 16, 200619 yr comment_163796 there are 2 pivot points on each strut. Upper strut bearing (PN 23-4376) and the lower ball joint (PN 23-4301)PN's are from the yellow 20th anniversary Edition from MSA (copy right 2002) Link to comment https://www.classiczcars.com/forums/topic/19656-strut-bushing-thingy/#findComment-163796 Share on other sites More sharing options...
