Posted April 17, 200619 yr comment_163917 I am installing a set of original seats in a 1972 240Z (purchased used and slighly moldy smelling) and noticed a scattered set of what appeared to be spacers. These are black plastic, one round, the other hex shaped. The hex shaped spacer is threaded.My question is - where are these suppoed to reside when mounting the seat? If above the bracket attached to the unibody, it will allow the seat height to be higher (if using) or lower (if removing). I assume this is where they are supposed to be.Not sure the explanation makes sense -- anyone have ideas? A picture maybe? Link to comment https://www.classiczcars.com/forums/topic/19672-seat-spacers/ Share on other sites More sharing options...
April 17, 200619 yr comment_163922 They are used to adjust the seat height. The hex shaped ones keep the round ones in place while installing the seat. Link to comment https://www.classiczcars.com/forums/topic/19672-seat-spacers/#findComment-163922 Share on other sites More sharing options...
April 17, 200619 yr Author comment_163954 Yes, that's what I thought, I am not crazy.Thanks for the response. Link to comment https://www.classiczcars.com/forums/topic/19672-seat-spacers/#findComment-163954 Share on other sites More sharing options...
April 18, 200619 yr comment_163996 Can I remove both the hex and the round spacers and mount the seat directly to the crossmember? I keep hitting my damn head on the stupid sun roof outer rail. :stupid: Link to comment https://www.classiczcars.com/forums/topic/19672-seat-spacers/#findComment-163996 Share on other sites More sharing options...
April 18, 200619 yr comment_164002 Can I remove both the hex and the round spacers and mount the seat directly to the crossmember? I keep hitting my damn head on the stupid sun roof outer rail. :stupid:I don't see why not. From my 1972 FSM:"Both seats can be adjusted 20mm (0.787 in) each upward and downward. The seat elevation is adjusted with the spacer indicated in dotted line in Figure BF-53. When it is desired to raise the seat, place the spacer on the seat riser. Contrarily, when desired to lower the seat, remove the spacer."I'm fairly sure each spacer is 10mm, so I suppose by default there were two spacers above and two (unused) below? That would allow for both 20mm up and 20mm down. I don't recall seeing that many spacers in my car, however. Link to comment https://www.classiczcars.com/forums/topic/19672-seat-spacers/#findComment-164002 Share on other sites More sharing options...
April 18, 200619 yr comment_164052 Very cool! I wondered why there were spacers above and below. Some of the ones below are missing but I don't need them anyway. This is going to make a huge difference for me. All I needed was another inch. Link to comment https://www.classiczcars.com/forums/topic/19672-seat-spacers/#findComment-164052 Share on other sites More sharing options...
April 18, 200619 yr Author comment_164073 Well, I am pretty certain there are only 2 spacers. The 20mm up would mean you include both spacers between the crossmember and the seat. The 20mm down implies removal of both IMHO.I'm not 100% certain, but my seats came with 4 pair per seat. Also, placing them below the cross member does nothing other than serve to limit the travel of the hex nut up the threaded bolt. Link to comment https://www.classiczcars.com/forums/topic/19672-seat-spacers/#findComment-164073 Share on other sites More sharing options...
April 18, 200619 yr comment_164133 The ones below were actually threaded onto the mounting bolt below the nut, so I assume they were just stored there in case you wanted to add even more. Dunno. Anyway, they're all coming off. Link to comment https://www.classiczcars.com/forums/topic/19672-seat-spacers/#findComment-164133 Share on other sites More sharing options...
April 18, 200619 yr comment_164136 I've removed the spacers to put a slant to the seat (ie removed 1 pair in the rear - kept both pairs on the front bolts)...works fine. Enigma - Don't see why you can't remove all and lower the whole seat for increased roof clearance....Should work fine ...(you could thread them on under the seat brackets for storage??)GWGarrard Link to comment https://www.classiczcars.com/forums/topic/19672-seat-spacers/#findComment-164136 Share on other sites More sharing options...
April 18, 200619 yr comment_164139 the 240zs I've bought from original owners (71 - 73) came with 4 spacers per seat mount bolt. 2 used between seat mount and cross-member and 2 stored on the bolt below the cross-member. when I go to pick n pull yards there are usually at least a few sitting on the floor pan of every Z in the yard. Link to comment https://www.classiczcars.com/forums/topic/19672-seat-spacers/#findComment-164139 Share on other sites More sharing options...
April 18, 200619 yr Author comment_164155 Interesting. I only have 2 per bolt, and I am surprised there is an extra set that goes below the cross member.No worries, I'll be removing them as they make me sit too high (and I am 5'7").One other question -- the aftermarket seats I had installed were not metric. The OEM seats are -- does anyone know the nut size for the seat bolts? I am assuming 13MM, but if someone knows, that would be a big help. Link to comment https://www.classiczcars.com/forums/topic/19672-seat-spacers/#findComment-164155 Share on other sites More sharing options...
April 18, 200619 yr comment_164166 I believe that the "standard" OEM mounting was with the 2 spacers used between the seat runners and the cross-member, and the two spacers stored below were intended to be moved above the cross member to raise the seat higher if needed.Seat mount bolt size is 8mm x 1.25, with an 8mm JIS nut which requires a 12mm hex wrench.Bolts are sized by diameter of threaded portion and thread pitch, then length of bolt. example: 8mm x 1.25 x 25mm The hex size is not used to identify the size of a bolt or nut.The OEM size of the nut for this bolt would be: 8mm x1.25 and would use a Japanese Industrial Standard (JIS) nut for which you would use a 12mm wrench. It is hard to find this nut in the USA unless you order from the dealer, most of the time at a hardware store you would find a 13mm hex on an 8mm x 1.25 bolt/nut. It will work fine but it's not the "correct" OEM size. Link to comment https://www.classiczcars.com/forums/topic/19672-seat-spacers/#findComment-164166 Share on other sites More sharing options...
