Posted April 18, 200619 yr comment_164078 Looking at a car with some front end damage: lhs headlight cracked and guard damaged, bumper cracked, bonnet slightly bent, rhs front guard slightly misalligned (noticable only when someone tells you where to look). Cant really see the rails under next to the engine - too much stuff on top, car appears straight form fornt and back, pillars and rood ok. So was wondering if its possible to check if the chassis was bent?Was thinking of trying driving a car and just looking at how it behaves but I assume that the wheels were not alligned after crash so it will be hard to tell what behaviour is due to chassis damage and which is due to un-alligned wheels... any suggestions?PS the car is not a 240Z but actually nissan silvia s13.Thank you in advance. Link to comment https://www.classiczcars.com/forums/topic/19690-how-to-tell-the-chassis-are-bent/ Share on other sites More sharing options...
April 18, 200619 yr comment_164081 On level ground, you can measure ride height at several locations side to side (assuming the tires are all the same and filled appropriately). Check the seams at the doors for irregular gapping. Also, see if the doors open and close properly. This isn't a sure way but may give you more insight into possible chassis tweaking. A few bucks at a frame shop will provide the answers you seek. Link to comment https://www.classiczcars.com/forums/topic/19690-how-to-tell-the-chassis-are-bent/#findComment-164081 Share on other sites More sharing options...
April 19, 200619 yr comment_164241 You could also check the wheelbase measurement, ie the distance between the wheel centres on each side. Whilst this is not a 100% solution it does give you an indication if one front wheel has gone back or not, assuming the rear of the car is undamaged. If the measurements are considerably different [more than 10mm] also check that the castor rod isn't bent. Link to comment https://www.classiczcars.com/forums/topic/19690-how-to-tell-the-chassis-are-bent/#findComment-164241 Share on other sites More sharing options...
April 19, 200619 yr comment_164244 hiyou could always take to a panel shop that has an chassis alignmentmachine if you really want to find out the axact measurementsdo not know how much they would charge but it would put your mind at easerobert Link to comment https://www.classiczcars.com/forums/topic/19690-how-to-tell-the-chassis-are-bent/#findComment-164244 Share on other sites More sharing options...
April 20, 200619 yr comment_164347 You could also check the wheelbase measurement, ie the distance between the wheel centres on each side. Whilst this is not a 100% solution it does give you an indication if one front wheel has gone back or not, assuming the rear of the car is undamaged. If the measurements are considerably different [more than 10mm] also check that the castor rod isn't bent.If you can get a tape measure under the car, check the diagonal measurements in addition to the wheelbase measurement of each side. If the car measures the same side to side and across both diagonals there isn't much chance that the frame is bent too badly. (Of course bent suspension parts can cause the measurements to be out of square, but you really want to know that those are ok as well.) Link to comment https://www.classiczcars.com/forums/topic/19690-how-to-tell-the-chassis-are-bent/#findComment-164347 Share on other sites More sharing options...
April 20, 200619 yr comment_164359 I've got an image with all the dimensions you're looking for, but it's too big to post here. PM me if you want it. Link to comment https://www.classiczcars.com/forums/topic/19690-how-to-tell-the-chassis-are-bent/#findComment-164359 Share on other sites More sharing options...
April 20, 200619 yr comment_164368 hiyou could always take to a panel shop that has an chassis alignmentmachine if you really want to find out the axact measurementsdo not know how much they would charge but it would put your mind at easerobertIf I was really interested in knowing the condition of the chassis, this is the only way I'd trust to confirm status of the car in question. Link to comment https://www.classiczcars.com/forums/topic/19690-how-to-tell-the-chassis-are-bent/#findComment-164368 Share on other sites More sharing options...
