Sounds good, I'm thinking of a stage 2 set up for the head with a 300 deg cam and .560 lift.
I'll have it mated to a set of Triple Miki's 44PHH. I'll be using a LD28 crank, unsure on rods still, custom pistons, larger valves in a P90 or N42 head.
I'm not too fussed on it being streetable, as long as it's fun! :)
Have you run yours in the 1/4 mile?
I've had a lot of trouble getting the timing correct. Having very little mechanical experience doesn't help :stupid: but even my mechanic (who is very experienced) has had trouble getting the engine to run smoothly.
This might help: http://forums.hybridz.org/showthread.php?t=111523
