Posted April 19, 200619 yr comment_164180 Finally getting things done in anticipation of zdayz! Its black with lime green accents to match the car, and then has a mirror clearcoat over it. Link to comment https://www.classiczcars.com/forums/topic/19697-powdercoated-my-valve-cover-today/ Share on other sites More sharing options...
April 19, 200619 yr comment_164187 This post is worthless without pics. Perhaps it just my pda thats not showing them.....If not, where's the pics? Link to comment https://www.classiczcars.com/forums/topic/19697-powdercoated-my-valve-cover-today/#findComment-164187 Share on other sites More sharing options...
April 19, 200619 yr comment_164190 unless he edited later there is a pic http://www.thepowdercoater.com/gallery/albums/userpics/10002/240_valve_cover.jpg Link to comment https://www.classiczcars.com/forums/topic/19697-powdercoated-my-valve-cover-today/#findComment-164190 Share on other sites More sharing options...
April 19, 200619 yr comment_164193 Enigma: He's inserted a link to the picture on his website. Maybe your PDA can't display it, or it takes forever to load?2003Z: What does something like that cost, without the green. Just polished aluminium accents on a black cover with nice clearcoat? Link to comment https://www.classiczcars.com/forums/topic/19697-powdercoated-my-valve-cover-today/#findComment-164193 Share on other sites More sharing options...
April 19, 200619 yr Author comment_164194 Enigma: He's inserted a link to the picuture on his website. Maybe your PDA can't display it, or it takes forever to load?2003Z: What does something like that cost, without the green. Just polished aluminium accents on a black cover with nice clearcoat?I'm not much into polishing, but if you could polish the accents first, it would run $60. $100 if I polish, plus shipping. Link to comment https://www.classiczcars.com/forums/topic/19697-powdercoated-my-valve-cover-today/#findComment-164194 Share on other sites More sharing options...
April 19, 200619 yr comment_164200 Mike, does the powdercoat cover the inside as well? Any problems with that? Link to comment https://www.classiczcars.com/forums/topic/19697-powdercoated-my-valve-cover-today/#findComment-164200 Share on other sites More sharing options...
April 19, 200619 yr comment_164202 I'm not much into polishing, but if you could polish the accents first, it would run $60. $100 if I polish, plus shipping.I'm not much into polishing either but I could ge it to where I want it before shipping it. I'll add this to my wish list and contact you when I have $$$ Link to comment https://www.classiczcars.com/forums/topic/19697-powdercoated-my-valve-cover-today/#findComment-164202 Share on other sites More sharing options...
April 19, 200619 yr Author comment_164205 Mike, does the powdercoat cover the inside as well? Any problems with that?for paying customers, I mask everything off so it doesn't get inside. Since this is mine, and its only cosmetic, as its not going to break down or anything, I didn't mask and probably got a little overspray in it. I am going to sand it off of the mating surfaces before install though. Link to comment https://www.classiczcars.com/forums/topic/19697-powdercoated-my-valve-cover-today/#findComment-164205 Share on other sites More sharing options...
April 19, 200619 yr Author comment_164206 I'm not much into polishing either but I could ge it to where I want it before shipping it. I'll add this to my wish list and contact you when I have $$$ok, let me know! Link to comment https://www.classiczcars.com/forums/topic/19697-powdercoated-my-valve-cover-today/#findComment-164206 Share on other sites More sharing options...
April 19, 200619 yr comment_164221 The cover looks really nice..... Link to comment https://www.classiczcars.com/forums/topic/19697-powdercoated-my-valve-cover-today/#findComment-164221 Share on other sites More sharing options...
April 19, 200619 yr comment_164228 for paying customers, I mask everything off so it doesn't get inside. Since this is mine, and its only cosmetic, as its not going to break down or anything, I didn't mask and probably got a little overspray in it. I am going to sand it off of the mating surfaces before install though.SO if the exterior is beadblasted or dipped to remove the yellowed factory clear, can you simply powdercoat it in clear to approximate the factory finish? Link to comment https://www.classiczcars.com/forums/topic/19697-powdercoated-my-valve-cover-today/#findComment-164228 Share on other sites More sharing options...
April 19, 200619 yr Author comment_164231 SO if the exterior is beadblasted or dipped to remove the yellowed factory clear, can you simply powdercoat it in clear to approximate the factory finish?Mine never had a clear on it, as far as I know. But yes, you can get it cleared in whatever gloss level you want. Flat, Semi, Satin, High or Mirror. There is even a blasted aluminum powder that can be applied first that looks like freshly blasted aluminum. I think the best would be to polish it, then clear coat, but thats just me. I've never actually seen one in a fresh factory finish. Link to comment https://www.classiczcars.com/forums/topic/19697-powdercoated-my-valve-cover-today/#findComment-164231 Share on other sites More sharing options...
