Fuel filter
Blue Meanie
bout a 1/4. Guess I'll just replace it for now. They aren't that expensive.
I would simply remove the filter from the clip while the car is idling and move it around to see if you can get the air bubble to pass on through. If the filter is clogged then your car won't run.
With mine, the filter is around three quarters full prior to starting and gives no trouble at all.
Previously, The car was a little hard to start. The filter would be less than a quarter full before starting. When I removed the old filter I found that the inlet hose had a slight crack in it. As the filter was not blocked, I SUSPECT that the slight crack in the hose was allowing air into the system, resulting in the fuel draining out.
Rick.
:devious: :devious:
  • Who's Online   2 Members, 1 Anonymous, 384 Guests (See full list)
