4 Wheel Alignment Settings
24OZ
Does anyone know the correct settings? I am taking the car in to check the alignment, they dont have the data sheets for the 240Z at the garage so can anyone help me out with the info id need such as the Toe-in setting and any other data that they'd need.
Thanks.
Well, the front toe-in is really the only thing that is adjustable on a stock Z. It should be somewhere between 2-5 mm toe -in, or .08-.20 in.
The front camber and caster are non-adjustable as are the rears unless you have installed the concentric camber bushings. You might be able to change the front caster slightly by tightening or loosening the mount on the T/C rod, but the results would probably be negligible.
My old Haynes manual gives the camber settings for the front as 50' + or - 30', and the castor as 2degrees 55' plus or minus 30'.
