Depending on the action of the engine , will effect what is going on with the breather from he valve cover . It is true the PCV at the end of the hose connecting to he bottom of the intake , draws fumes from the crankcase. However when the throttle is opened the vacuum drops and if there is blow by from the cylinders it will come out of the breather . the breather should be connected to the air cleaner box. This way any fumes will be burned by the engine and if any air is need , not likely , for the block it will be filtered air . It is normal to have some discharge form the breather . However when an engine becomes tired the emissions will increase . My 2 cts. Gary
https://www.classiczcars.com/forums/topic/19721-question/#findComment-164488
can some one tell me where i can get some goos hoses for cheap??
Now if you're talking about really good hoses, check out the CV4 website. Very nice silicone hose and in different colors but, not cheap. Otherwise, if you are just looking to replace the stock hoses, contact Courtesy Nissan in Texas.
https://www.classiczcars.com/forums/topic/19721-question/#findComment-165263
What is the URL for this site. I went to cv4.net but their online catalog sucks and doesn't list any silicon hoses.
https://www.classiczcars.com/forums/topic/19721-question/#findComment-165271
