Posted April 20, 200619 yr comment_164467 So I tuned up my carbs. and something puzzled my brother and I. There was grayish smoke coming out of the breather valve on the valve cover. Is this supposed to happen because the car has not been run in 7 years. thx Ian:nervous: Link to comment https://www.classiczcars.com/forums/topic/19721-question/ Share on other sites More sharing options...
April 20, 200619 yr comment_164470 I would say it is because your PCV valve is not working or is not hooked up, the breather on the valve cover is an air intake, the pipe coming out of the block below and in front of the carbs should have a hose going to the pcv valve and is the output. Link to comment https://www.classiczcars.com/forums/topic/19721-question/#findComment-164470 Share on other sites More sharing options...
April 21, 200619 yr comment_164488 Depending on the action of the engine , will effect what is going on with the breather from he valve cover . It is true the PCV at the end of the hose connecting to he bottom of the intake , draws fumes from the crankcase. However when the throttle is opened the vacuum drops and if there is blow by from the cylinders it will come out of the breather . the breather should be connected to the air cleaner box. This way any fumes will be burned by the engine and if any air is need , not likely , for the block it will be filtered air . It is normal to have some discharge form the breather . However when an engine becomes tired the emissions will increase . My 2 cts. Gary Link to comment https://www.classiczcars.com/forums/topic/19721-question/#findComment-164488 Share on other sites More sharing options...
April 27, 200618 yr comment_165251 can some one tell me where i can get some goos hoses for cheap?? Link to comment https://www.classiczcars.com/forums/topic/19721-question/#findComment-165251 Share on other sites More sharing options...
April 27, 200618 yr comment_165263 can some one tell me where i can get some goos hoses for cheap??Now if you're talking about really good hoses, check out the CV4 website. Very nice silicone hose and in different colors but, not cheap. Otherwise, if you are just looking to replace the stock hoses, contact Courtesy Nissan in Texas. Link to comment https://www.classiczcars.com/forums/topic/19721-question/#findComment-165263 Share on other sites More sharing options...
April 27, 200618 yr comment_165271 Now if you're talking about really good hoses, check out the CV4 website. Very nice silicone hose and in different colors but, not cheap. Otherwise, if you are just looking to replace the stock hoses, contact Courtesy Nissan in Texas.What is the URL for this site. I went to cv4.net but their online catalog sucks and doesn't list any silicon hoses. Link to comment https://www.classiczcars.com/forums/topic/19721-question/#findComment-165271 Share on other sites More sharing options...
