May 27, 200618 yr comment_168923 Why are Fel pro's poor?I built my engine around a 1mm gasket (felpro) a little while later we had to strip the head off (inducted a rivet from the air box into number 6 and bent a valve) I decided to put a 1mm HKS on for a trial and from that moment on had issues of water leaks, poor compression and loss of power. I stripped the head off after a few meets to fit new springs (a set doesn’t last long at 7500 rpm and measured the HKS, using a dial gauge on the valve it was 1.18 mm and using a calliper on the bore yielded 90.5 where as the Felpro was a true 1mm and 88.5 mm bore, all of this equated to about 1.6 cc increase (about .5 of a compression point). Also when we designed the engine, the compression was specified at 11:1 and the squish area was engineered to 48 thou (pistons 8 thou under deck and a gasket of 40 thou or 1mm = 48 thou) altering this with the HKS completely changed the characteristics of the engine.Whilst we had the HKS on we never achieved better that 13.8 on the quarter (20 runs)Now we have a fel pro back on, we are back on form again running 13.4 quarters, 4.72 seconds 0-60 and in excess of 250 at the fly with no leaks, plus they are a damn sight cheaper than a steel which is more suited to forced induction or really big compression blocks engines. Link to comment https://www.classiczcars.com/forums/topic/19751-question-about-deck-height/?&page=2#findComment-168923 Share on other sites More sharing options...
May 27, 200618 yr comment_168924 Why are Fel pro's poor?Hard to say for certain. There are plenty of people here and elsewhere who have had, or know someone who has had a bad experience with Fel-pro. But ask around a bit and you can find plenty of people who have NOT had any problems with Fel-pro and continue to use them all the time.So I don't know. I can't imagine that I will need a steel head gasket for the stock L24 I'm starting to rebuild, so no way I'll pay for an HKS. Will I use Fel-pro? Maybe. Depends on what I can find affordably. I strongly suspect that most any normal gasket will work for my uses, if given proper preparation and installation. Link to comment https://www.classiczcars.com/forums/topic/19751-question-about-deck-height/?&page=2#findComment-168924 Share on other sites More sharing options...
May 27, 200618 yr comment_168928 Sorry I missed this thread earlier when the topic of metric conversions and calculations came up but I thought I would point out how useful Google is for things like this. No, I'm not talking about searching for a calculator. I'm talking about using Google as the calculator. Simply go to Google and in the search box type whatever you need. Here are some examples:.030mm in inches2+270mph in kph3.5 USD in GBP150000 JPY in USD Link to comment https://www.classiczcars.com/forums/topic/19751-question-about-deck-height/?&page=2#findComment-168928 Share on other sites More sharing options...
