I have a 73 and am converting over to 72 SU's. I got the flat tops off the car, but noticed that there are not holes in the heat shield to connect the springs from the carbs. do I need a new heat shield or can I simple add some holes to my existing shields? How critical are the locations?
Tx,
Bill
https://www.classiczcars.com/forums/topic/19756-heat-shield-carb-springs/
Tx,
Bill
well the locations are a specific distance from the carb linkage, as to create a certain amount of pullback . if you go too short on distance for example,
when you let off the gas your carbs may not completely close to idle.
if you go too long, youll have a "hard gas pedal" feel...meaning you have to push too hard to give the car gas...which can make it difficult to drive.
A small point but I would make a wire loop affair to hook into the sharp edged hole in the heat sheild. The sharp edged hole in the heat sheild will then over time saw thru the wire loop instead of your spring. Cheap and easy to form another wire loop.
Bill, the '72 round top carbs have a water passage and will work with the '73 intake manifold. So, you should be able to leave the coolant lines connected to the intake. It will provide a quicker warm up in cold weather.
Here are a few pics showing the differences between the '72 and earlier round top carbs. In the photo with the two carbs side by side, the one on the right is a '72 carb with a water passage at the bottom of the manifold side. The one on the left is off a '71 and does not have the water passage.
The second photo shows the top of the '72 carb, it is also referred to as a 3 screw carb. Look close and you'll notice that there are three screws that mount the dome to the carb body. The last photo shows the top of the '71 carb, also referred to as a 4 screw carb. You'll see four screws that mount the dome to the body.
If it turns out that you have the earlier round top carbs then you will need to disconnect the coolant lines to the intake and block them off on the engine side, or replace the intake with a '71 or earlier intake.
When I bought my '73 it was setup with '72 round tops and the '73 intake. Keep us posted with your progress!
