Posted April 25, 200618 yr comment_165056 Ok. I've been troubleshooting HVAC and found that when I test for voltage at the solinoid connector on the fender only one set of pins shows 12v with the key on.Both sets of pins do have continuity though. Can anyone verify that this is either correct or incorrect before I go and tear things apart. Thanks Link to comment https://www.classiczcars.com/forums/topic/19781-solinoids/ Share on other sites More sharing options...
